| bhlonewolf Senior Member
          Hi gurus,
           | Posted: June 22 2007 at 12:37 | IP Logged |   |
 I have a 2 buttons linked to some lights outside my garage.   All works as expected.
 I have an x-10 keychain remote that sends a command to powerhome to turn on the lights.  A motion sensor does the same thing.  It triggers a macro to turn on the light, wait 5 minutes, then turn it off.  This works fine, too.
 What I'd like to do is: if a user turns on or off the light manually (at either switch) I kill the waiting macro.  I'm having a hard time differentiating between a user hitting the switch, or a second press of the keypad, etc.  Is there a way to set up a trigger to listen for local control only?
