        | BeachBum Super User
          Any thoughts why I can’t get this to work??
           | Posted: August 07 2007 at 16:22 | IP Logged |   |
 IF (PH_GETINSTEONLEVELRT("KITCHEN") = PH_GETGLOBAL_S("LEVEL_KITCHEN"), 1, 2)
 LEVEL_KITCHEN is  = to o (zero). KITCHEN is an Insteon device which is in the off state. If I break it apart the separate commands run fine as a formula and both return 0.
 Pete - X10 Oldie
          Beachbum,
           | Posted: August 07 2007 at 17:40 | IP Logged |   |
 ph_getinsteonlevelrt() returns a double (numeric) value and you're comparing that to ph_getglobal_s which returns a string.  Change it to ph_getglobal_n and it should work.
        | jbbtex Senior Member
          If LEVEL_KITCHEN is a global variable this should work:
           | Posted: August 07 2007 at 17:57 | IP Logged |   |
 if(ph_getinsteonlevelrt("KITCHEN")={LEVEL_KITCHEN},1,2)
        | BeachBum Super User
          Dave, jbbtex..
           | Posted: August 08 2007 at 08:44 | IP Logged |   |
 Thks, I thought it might be a mix of values that was the problem. Both methods worked fine.
 Pete - X10 Oldie
