        | eHomeCreations Groupie
           | Posted: November 09 2007 at 16:37 | IP Logged |   |
 |  Morning all!
 In my eHome screen designer program, I am trying to setup the socket server for Insteon. I have it working for X-10 and macros just fine. I do not have access to Insteon here in Europe at all.
 With the socket server... I am using:
 ph_insteon("BM BAR PEND",17,255)  Turn on Insteon ID "BM BAR PEND"
 ph_insteon("BM BAR PEND",19,0) Turn off Insteon ID "BM BAR PEND"
 I sent a test program to one of my users. This syntax does not seem to work. The program is just a quick  modification of Dave's Socket Socket server sample. It works with X-10 and macros just fine. i can also send anybody else the test program.
 Any help would be appreciated.
 --Steve       http://www. ehomecreations.com
        | TonyNo Moderator Group
          That looks like it should work.
           | Posted: November 09 2007 at 17:27 | IP Logged |   |
 |   Is the user sure about the ID? |
           | Posted: November 09 2007 at 17:31 | IP Logged |   |
| TonyNo wrote:
       | That looks like it should work.  Is the user sure about the ID? |  |  |
 Yes, After some problems he sent me his Powerhome DB. I plugged in the values and sent him back the test code. I am 99% sure the ID's are right.
          OK. this is right. The problem was the socket server!
           | Posted: November 12 2007 at 13:50 | IP Logged |   |
