        | seekingdave Newbie
          Hi all,
           | Posted: October 29 2007 at 08:40 | IP Logged |   |
 Sorry about the dumb question but I know it must be simple to work out when you know what you are doing
 I am trying to have a Macro start at a given time the next day, what I mean is I have set up a button for the morning routine macro in the control center and when pushed I need it to start at 7.30 for the next two days and not the time that I push the button, then next time I press the macro button, two days from that press etc.
 Hope this makes some sense to you, looking forward to your help.
 Cheers
 Dave
        | jbbtex Senior Member
          Here's one way.
           | Posted: October 29 2007 at 09:25 | IP Logged |   |
 Create a global variable.
 Have the CC button set the value of the global to 2.
 Create a timed event to start your macro every day at the time you desire.
 Have the first line of the macro check the value of the global.
| Code:
       | JUMP  IF("YOUR GLOBAL">0,1,999) |  |  |  If the value is greater than zero, continue the macro, otherwise quit.
 Have the last line in the macro set the global to 1 less. After the second day, the global will be zero and the macro will quit after the first line.
        | seekingdave Newbie
          Hi and thanks for the reply,
           | Posted: October 29 2007 at 10:46 | IP Logged |   |
 Sorry to be a real Newbie but could you break this down into CHILD steps for me (PLEASE!!)
 Sorry again for this
 Cheers
 Dave
           | Posted: October 29 2007 at 12:19 | IP Logged |   |
 Welcome to PowerHome!
 This should be a fairly simple task with several ways of accomplishing.  The way jbbtex outlines should work just fine but it may just be easier with a formula.  The way I would do it is to set the Control Center button to execute the following button when pressed:
 ph_createtimedevent(0,"YOUR MACRO ID",datetime(relativedate(today(),1),07:30:00)) + ph_createtimedevent(0,"YOUR MACRO ID",datetime(relativedate(today(),2),07:30:00))
 That's it.  What it does is create two "one-shot" timed events for the next day at 07:30 and the day after that at 07:30.  Be sure and substitute the "YOUR MACRO ID" for the ID of the macro that you wish to run.
        | seekingdave Newbie
          Hi Dave
           | Posted: October 29 2007 at 13:09 | IP Logged |   |
 Thanks so much for the quick reply, and for the amazing software you have done a fantastic job (even a complete idiot like myself can work my way around this
  ) but it is great to have the forum here for the help, I am sure to ask a LOT of stupid questions so will say sorry now!!.
 Another stupid  question if you have time, is it possible to test a macro and cancel it half way through.
 Thanks again
 Dave
        | TonyNo Moderator Group
          In the macro, just check the "skip" boxes on the lines that you don't want to execute during your testing. Just make sure to clear them when you are done.
           | Posted: October 29 2007 at 14:06 | IP Logged |   |
        | seekingdave Newbie
          Thanks very much for all the help.
           | Posted: October 29 2007 at 14:55 | IP Logged |   |
 Cheers
 Dave
