wobbles Newbie
| Posted: February 27 2008 at 16:20 | IP Logged
Hey guys,
Tony made my life much easier in my last posting, and I now have the worlds simplest question:
in any scripting format, what is the simplest way run to run this when the script is executed:
x10 device A1 on, wait 1 second, X10 A1 off.
simple eh?
| Posted: February 27 2008 at 19:30 | IP Logged
Deleted....
Edited by BeachBum - February 27 2008 at 19:34
| Posted: February 27 2008 at 19:40 | IP Logged
I’ll try this again.. If a macro qualifies as a scripting format then…. assuming you have the device defined in setup under devices and your ID for A1 is something like LAMP then the easiest way would be to create a MACRO with entries:
COMMAND: X-10 ID: LAMP VALUE: ON
COMMAND: WAIT Send Keys: 1
COMMAND: X-10 ID: LAMP VALUE: OFF
wobbles Newbie
| Posted: February 27 2008 at 19:52 | IP Logged
Where do i put this macro in Powerhome? when I open macros in PH explorer it has a build your own dropdown functionality and no where to copy/paste. and the command option is not available.
| Posted: February 27 2008 at 20:00 | IP Logged
You start by going to PowerHome Explorer then to Macros. Page 35 of the Users Manual shows this info.
| Posted: February 28 2008 at 09:12 | IP Logged
Another source of information I forgot is Tony’s tutorial.
http://tonyno.ods.org/ph/PHTutorial1-AddingDevicesandMakingT hemDoSomething.htm
