         milosz Newbie
           | Posted: December 22 2013 at 05:33 | IP Logged
I'm using PowerHome via a SmartHome 2414u controller; I
 have about fifteen SmartHome 2456S Insteon On/Off
 "appliance linc" controls.
 For whatever reason, my 2456S Insteon On/Off "appliance
 linc" controls don't always "hear" the command to turn on
 or off - could be RFI or other noise, I don't know.
 When PowerHome tells "LAMP1" to turn on, for example, and
 "LAMP1" in fact DOES NOT turn on, PowerHome shows a green
 "ON"  status anyway.
 What gives?  I thought Insteon switches were capable of
 reporting actual "ON" or "OFF" status, that PowerHome was
 capable of communicating with Insteon devices to learn
 their status, and that PowerHome would display the actual
 status that the Insteon device reported. Powerhome is
 showing "ON" status for devices that it TOLD to turn on,
 but that are not ACTUALLY on.
 If the "LAMP1" doesn't turn on when the PowerHome timed
 event told it to, I  click the "ON" button in the
 PowerHome interface and the lamp will usually turn on. My
 understanding was that PowerHome would keep trying to
 turn "LAMP1" ON until it reported back that, indeed, it
 was ON.
  Edited by milosz - December 22 2013 at 05:35
           | Posted: December 22 2013 at 11:39 | IP Logged
Do you have the modules linked to the controller? That is the only way PH would know the actual status.
 PH will not keep forcing the status that it has. You can program that yourself, though.
           | Posted: December 23 2013 at 15:36 | IP Logged
Milosz,
 It sounds as if you might not have the "Update on ACK" option checked.  With this option unchecked, PowerHome will update status as if a command succeeded.  Checking this option will cause PowerHome to only update once it gets an ACK back from the controlled device (which should mean that it received the command and did as it was instructed successfully).
 PowerHome will eventually update the status if you've got "Enable pending" checked, "Status Scan" checked, and a "Poll Interval" > 0.  With these settings, if no other background operations are pending, PowerHome will poll the status of devices in a loop.  Depending upon where the device in question is in the loop is how long it will take to update the status.
 Probably the real issue though is that "Update on ACK" is not checked so you're getting the status updated automatically when a command is sent.
         milosz Newbie
           | Posted: December 26 2013 at 04:54 | IP Logged
That's not it.  Look at this screenshot.
         milosz Newbie
           | Posted: December 26 2013 at 04:56 | IP Logged
 status.
 program that yourself, though. |
 Yes the modules are linked.
           | Posted: December 29 2013 at 19:11 | IP Logged
milosz,
 Sorry to take so long responding.
 Since the "Update on ACK" is checked, you should not be seeing that behaviour.  Would it be possible for you to "Echo Raw Log to File" while controlling the appliance module where the status does not match the actual state?  It will help in determining what may be going on.
 Remember, you'll need to edit the path/filename for the raw log in the Controller settings.
         milosz Newbie
           | Posted: January 11 2014 at 06:20 | IP Logged
dhoward wrote:
       milosz,
 How do I do that?  I don't see any option for editing the
 path/filename.
           | Posted: January 11 2014 at 09:40 | IP Logged
Try Setup > Controllers > Settings > "Echo Log File"
 Don't forget to reinit.
         milosz Newbie
           | Posted: January 22 2014 at 12:42 | IP Logged
 "Echo Log File"
 Don't forget to reinit. |
 OK, but where is "SETUP?"
           | Posted: January 22 2014 at 12:53 | IP Logged
Go to Windows drop down and check Powerhome Explorer. You should see it in the left side. Also try clicking on E in the toolbar. See if that gets you there.
