         mustangcoupe Super User
           | Posted: January 31 2009 at 14:53 | IP Logged
ok, ive been around a bit ans I still get confused with ' and " ...
 can someone help me here... I am sending a command out using the PH.run command to send CID info to all computers on my network.
 here is the basics of what I am tring to do...
       | "C:\Program Files\Windows Home Server\WHSAlert.exe" "Incomming Call" "CID INFO HERE" info 100 |
 ph.run(file name argument1 argument2 argument3 argument4)
 file name: C:\Program Files\Windows Home Server\WHSAlert.exe
 argument1: Incomming call
 argument2: globalvariable {CID}
 argument3: info
 argument4: 100
 each argument needs to be sent in quotes to be processed properly
 thanks
 HA newbie
     PowerHome - UPB - ELK
         jbbtex Senior Member
           | Posted: January 31 2009 at 20:18 | IP Logged
If you haven't already you might try it like this.  I don't use windows script so my example uses ph_run and this is just a guess.
       | ph_run("'C:\Program Files\Windows Home Server\WHSAlert.exe '" +  "'Incomming Call '" + "'" + "{CID}" +  "' " + "'info '" + "'100'") |
 But I'm like you, all the quotes start running together and make my eyes glaze over.
  __________________ Brady
           | Posted: January 31 2009 at 20:45 | IP Logged
getting better... I dont get a formula error but I do get a -1 response
 HA newbie
           | Posted: January 31 2009 at 21:34 | IP Logged
-1 means there was an error.
 Try it by substituting a string for the GV.
       | ph_run("'C:\Program Files\Windows Home Server\WHSAlert.exe '" + "'Incomming Call '" + "'test string '" + "'info '" + "'100'") |
 edit: Thought I put this in the first time.
 If it does work then we can figure out how to get the variable in.
  Edited by jbbtex - February 01 2009 at 03:44
