         jpkelly100 Newbie
           | Posted: January 25 2009 at 02:22 | IP Logged
Will HomePower 2 communicate correctly with DCC 1.1 . I'm trying to get TTS from PH to the DCC, but when i Verify in the Formula builder on the PH machine,it keeps giving me a 401 Unauthorized. When i run the Formula i get no results at the DCC. The DCC is connected to PH and is listening for requests. I have turned firewall off on DCC machine. With the same 401 result.
         jbbtex Senior Member
           | Posted: January 25 2009 at 14:44 | IP Logged
Check your password in the dcc.ini.  It must be the encryted version from the pwrhome.ini file under the [Socket Server] section.
  __________________ Brady
         jpkelly100 Newbie
           | Posted: January 25 2009 at 21:35 | IP Logged
I did a copy, paste to make sure i got the password correct. There was another post about that. I am at a total loss as to what is going on. The PH machine can see the DCC as it gives me that info above the 401 message. I'm an Admin on both machines, so i don't believe that is the issue either.
