Johnny Newbie
| Posted: September 18 2011 at 20:54 | IP Logged
As the last bug report is from Feb 2011, I'm not sure it's the right place .... It could also be a very good news ... PH is really a stable product !
Anyway, I've only x10 modules operating with PH2 latest version. Right now, I'm checking stability (so far so good) of my old PLC 2814u in monitoring X10 coming from my standalone CM15. I also installed some motion detectors through PH2 (I could not really use them with the CM15).
Tonight, in the log report, I noticed that PH2 sees the bright and dim commands but it looks like PH2 cannot interpret them to evaluate the current status of the different modules where bright/dim is possible. All status having ADim box are 100%, but in fact they are all around 70%. So there's probably something somehwere that I didn't properly set.
In PH1 I remember I had to enter some data to give PH the information on the total number of Bright/dim commands required to go from 0 to 100% or reverse. I couldn't find a place to enter that information in PH2.
As I also had critical error in trying to use the Adim in the same Status Device, it looks like PH2 misses the information on how much a bright/dim command changes power.
So I really think I'm missing a setting somewhere. Has someone an idea where is it ?
