PowerHome Macros, Scripts, and Formulas Repository
 PowerHome Messageboard : PowerHome Macros, Scripts, and Formulas Repository
Subject Topic: Weather Warnings Post ReplyPost New Topic
Posted: December 20 2006 at 20:11 | IP Logged Quote TonyNo
This is a macro to get local weather alerts. The only problem that I can see is that this uses polling, and sometimes warnings are issued only minutes before the event is to occur.
Create a new Global Variable called "CURWWA", and update your zone info in the ph_geturl line. Zone info is available here by drilling-down to your location (click on the correct XML button).
WWA2
demko
Posted: January 14 2009 at 22:56 | IP Logged Quote demko
Sorry if this is a stupid question, but I'm still new at this. What's the difference between the "WWA 2" and the "WWA2" macros? I can't seem to see a difference.
Also, I was wondering if you could help me out with figuring something out. I setup a timed event to run this macro "WWA 2" every 5 minutes. What I'd like to do is kick off a macro I created (flashes a light a few times) if a new warning is issued. Any idea how I could do that?
Thanks for any help!
Back to Top View demko's Profile Search for other posts by demko
BeachBum
Posted: January 14 2009 at 23:17 | IP Logged Quote BeachBum
I store the context of the alert I am using in a global and compare it to the new to see if there is a change. If so I then create a time event for a newer wwa2. If not then the next time event is created for much later.
Pete - X10 Oldie
Posted: January 15 2009 at 08:01 | IP Logged Quote TonyNo
If you put your macro call at the end, it should work. The 2nd to last line looks for a change.
