           | Posted: November 26 2012 at 14:07 | IP Logged
Skip,
 Nope, Lee, Jeff, Tony, Ken, Pete, Noel (and others) are all just PH zealots.  Im basically a one man show.
 My "real" job is as a software engineer for a major defense contractor.  However, 28 years ago I got my start in software engineering with an environmental controls contractor when DDC (Direct Digital Control) was just emerging and cut my teeth in that industry with TSBA controls.  Basically everything I did then for building automation and control is what we're realizing now in home automation.  PowerHome definitely does not pay the bills  .
 As Lee pointed out, SmartHome does make available an SDK which I bought into (preordered actually) when they were first made available.  It does get you access to critical documents required for Insteon programming but alot of stuff is missing and must be determined via extensive testing.  Its been a long and interesting trip working with Insteon.  PowerHome was actually the first (or one of the first) software packages to support Insteon software linking back in the 2005/2006 timeframe and the only one at the time that did this by crawling the entire Insteon network and storing it in its own local database.
         jeffw_00 Super User
           | Posted: November 26 2012 at 14:12 | IP Logged
Hey Dave - small world - I work for a small company doing primarily defense contracts (wireless and SATCOM).
 FWIW - Steve Lee @Insteon thinks the world of you.  Not sure how much you talk to him but might be worth a call next time you hit a roadblock at SH.
 Dave called me a Zealot!  I'm so proud!  8-}  (actually, I wasn't sure he ever forgave me for the first review of PH (Rev 1.0) I wrote in Home Automation 100 years or so ago).
 best
         traviskleckner Senior Member
           | Posted: October 17 2013 at 08:48 | IP Logged
I'm ~100% sure this has been covered somewhere else, but
 the 2.1.4b patch doesn't allow configuring a KPL right?
 I've got a new relatively new one (V6.2, it's been
 sitting in a box waiting for setup for a couple months
 now) and it seems that I can do the links just fine but
 while KPL config loads it gives me crazy random data.
 Also, interestingly, it must be reporting a different
 device type as it didn't come up as a 2486D.  Is that
 normal?  Are the new I2CS devices considered different to
 PH? (which, given that the communication is probably
 totally different makes sense.)
           | Posted: October 17 2013 at 22:29 | IP Logged
“ but the 2.1.4b patch doesn't allow configuring a KPL
 right? “
 Correct, PH KPL configuration cannot configure the new
 KPLs
 “Also, interestingly, it must be reporting a different
 device type as it didn't come up as a 2486D.”
 It is likely a Dual Band KPL which does carry a unique
 cat/subcat (device type)
 “Are the new I2CS devices considered different to PH?”
 They are different in that they will always have a
 different firmware level then the non I2CS variant.  The
 Insteon interface is very different.  The messages have
 additional requirements and they have special linking
 requirements. Some commands have been removed completely.
 They usually have the same cat/subcat until a major
 feature changes such as going to Dual Band.
         MrGibbage Super User
           | Posted: December 02 2013 at 17:18 | IP Logged
Dave, seeing how it's been over a year since the 2.1.4b
 came out, I was wondering if there was any news on the next
 version's progress. For the most part, everything is
 working fine, but I always get all giddy over new releases!
  __________________ Skip
           | Posted: December 02 2013 at 18:18 | IP Logged
Skip,
 Im hoping to have 2.1.5 by year end.
           | Posted: December 02 2013 at 19:15 | IP Logged
Awesome! Thanks for the update! That *WILL* be a nice Christmas present. Can you tell
 us a little about what to expect in 2.1.5?
           | Posted: February 24 2014 at 07:42 | IP Logged
Dave, can we get an update on 2.1.5? And maybe a feature
 list/changelog?
           | Posted: February 27 2014 at 14:15 | IP Logged
So, fully understanding that #1, you are a busy guy and #2
 you have a bug(s) that's holding up the next version, is
 it possible to get an Alpha version?  I've got a couple
 keypads that need to be configured beyond what I can do
 without software.
 Could we *maybe* have an Alpha version that could be used
 for testing (and KPL Config) but not as a live system?
 Pretty please?
           | Posted: February 27 2014 at 14:47 | IP Logged
Dave, for the record I am not trying to be pushy. My PH installation is working great. But I always
 get all squishy and excited when new stuff is on the horizon. I don't mind waiting for it. That being
 said, if you need testers, I would like to offer my services as well. Bottom line though, take your
 time.
           | Posted: March 03 2014 at 10:12 | IP Logged
An update on 2.1.5...
 The lockup requiring a reboot bug that Ive been fighting for months appears to finally be fixed.  It was tracked down to the new multi-threading model and resulted from a conflict of simultaneous access to resources.
 With that finally done, two things remain before I'll have a version ready to release.  The first is the labeling system.  I was partially done with it and was going to release as is until I discovered that some basic core functionality was being blocked.  As such, it was easier to just finish up the labeling basics than trying to remove it all together for this release.  The second item is to add the support for the Insteon motion sensor configuration since I had forgotten about getting that part included.
 Since there have been several requests of an alpha, I will go ahead and release this version as soon as I have it compilable.  This will mean that the change log, help file, database upgrade, and installer will not yet be ready.  This alpha will need to be manually installed and you'll essentially have to start with an empty database in order to test with but should give you an idea of what will be available with the beta.  I'll then release the rest of the items as I get them completed.  The first will be the changelog, followed by the help file, and then finally the database upgrade utility.  The last step will be to release the complete upgrade as an installable package with all the individual components included.
 Hope this helps.
         jeffw_00 Super User
           | Posted: March 03 2014 at 10:48 | IP Logged
Hi Dave - thanks very much for the update.  Full support for motion sensor is a good thing, thanks!.
 Also - I'm hoping you've addresssed these?
  http://www.power-home.com/forum/forum_posts.asp?TID=3219&PN= 3
  http://www.power-home.com/forum/forum_posts.asp?TID=3230&PN= 3
 If not, there isn't a rush, but if they were in the "complete upgrade" release that would be awesome!  Thanks!
           | Posted: March 03 2014 at 11:00 | IP Logged
Jeff,
 Both of the referenced issues should be fixed.  Specifically the problem with rebuilding of Insteon links and the other I2CS problems.  The Insteon engine including the I2CS was completely rewritten for this upcoming release.  There may be some new bugs (I hope not) but the current crop of bugs primarily associated with I2CS should have been eliminated  .
         jeffw_00 Super User
           | Posted: March 03 2014 at 12:02 | IP Logged
Hi Dave - thanks!  Looking forward to mucking with it.
 (BTW - my rebuild issue wasn't limited to I2CS devices, I was also having trouble linking some ControlLincs)
           | Posted: March 07 2014 at 19:10 | IP Logged
       Good idea... We'll let Ken work on it he loves
 those kind of things. Dave's got enough toys he probably could beam
 us up in his back yard. |
 Ken here Peter.
 Just arrived in Ocala, FL a few days ago, and here now until May.  Was
 just about to contact Dave to see about our annual get together.
 If Dave is willing to host us at home again, we should be able to Skype
 for awhile.  If he doen't have a camera, we can use my iPhone.  I figure
 if we bring things and make it potluck, then we can minimize any
 workload on Dave/Mira.
 Other than March 17-28 when we are on a brief cruise to Panama, we
 are good for a gathering.
 Hope your schedule is open.
 I've been working for months to rewrite as many of the PH Help files as
 possible.  I've been adding copious examples to each, in the hope it will
 help new PH Users have an easier time getting started.
 Also been writing FAQ pages to share many of the marvelous tips that
 Dave, and others in the Forum have revealed and I was afraid might
 get lost over time.  I have built a collection of these FAQs over the
 years and have found them very valuable.  It seemed like a good time
 to share them.  :-)
 Hopefully these wriiteups can get incorporated in the next PH release.
           | Posted: March 07 2014 at 22:52 | IP Logged
I knew those old quotes would come back sooner or later. What took you so long to get to Florida? Looks like you've been busy while locked in this winter. Your cruise is taking place while I'll be in the area so anytime would be fine. Pot luck won't work because of the distance but then again I don't consume much.
