         RichardL Senior Member
           | Posted: April 15 2009 at 12:05 | IP Logged
Is there a "startup script" in Powerhome?
 I want to define certain global variables upon PH startup.
 If there is no startup script, how else can I be positive a global variable is defined with a specific value each time PH starts?
 Thank you,
 Richard
         nadler Super User
           | Posted: April 15 2009 at 12:17 | IP Logged
Define a Trigger as Trigger Type 'System Process' and
 Trigger Id as 'Startup'.  Every time PH is started
 whatever Action and Action Type you define will be run.
 It can be a macro, formula, raw formula etc.
 If you need more detailed info just ask.
 Noel
           | Posted: April 15 2009 at 12:52 | IP Logged
Beautiful!
 I set it up and it is perfect!  I also noticed the ability to execute at "reinitialize" and "shutdown".
 The Reinitialize and Startup are both in place and identical.
 Now that I have the variable dependable, I am continuing testing/tweaking my latest KeyPadLinc dependency issue.
 You may see that on another post real soon!
 Thank you!
 Richard
