Subject Topic: Internal TimedEvents date wrong Post ReplyPost New Topic
moniputer
Posted: August 21 2015 at 08:51 | IP Logged Quote moniputer
PH came up with a system date of 10/20/15. I have
corrected that and re-started PH but now all timed events
are scheduled for 10/20/15.
How to I correct this?
Back to Top View moniputer's Profile Search for other posts by moniputer
Posted: August 21 2015 at 09:16 | IP Logged Quote dhoward
Moniputer,
You could correct this with the following SQL
statement executed in the PH Multi-Editor in SQL mode
(shift-F5):
update timedevents set starttime =
dateadd(day,-60,starttime),reftime =
dateadd(day,-60,reftime)
You would want to first stop timedevents, then execute
the sql, open the PH Explorer and check everything is
ok and then restart Timed events. This SQL would bring
everything back to today's date (10/20/2015 is 60 days
different from today).
As with anything sql, its very easy to corrupt your
database so I would probably take a backup first. You
could also correct the timed event entries by hand in
the PH Explorer if you'd rather not use SQL.
moniputer
Posted: August 21 2015 at 09:36 | IP Logged Quote moniputer
Thanks Dave!
Joe
