        | funbobbybaby69 Groupie
          Last week i installed ph2 and added all my insteon devices manually.  tested each one and they all work (except the 7 buttons on my kpl - #1 works but not the others yet) and the ezio. but thats another issue...lol
           | Posted: May 03 2010 at 09:51 | IP Logged |   |
 my question is i have 14 pending operations that dont seem to be going away and all my lights on each insteon devices are constantly blinking.  (like i said for over a week now)
 shouldn't these pending operations be completed by now?
        | grif091 Super User
          Assuming Enable Pending is checked the pending operations should be processed.  You may have the Status Scan option also set which causes all the devices to be constantly scanned for status and updates.  I would suggest not running with the Status Scan option set.
           | Posted: May 03 2010 at 10:58 | IP Logged |   |
 You need to link the other KPL buttons for them to be able to trigger events or be controlled through Group commands.  Powerhome2 does not automatically create links for the additional buttons.
 Edited by grif091 - May 03 2010 at 11:01
 Lee G
          Thank you,
           | Posted: May 03 2010 at 11:13 | IP Logged |   |
 yes the Enable Pending is checked and yes the status scan option was checked.  I uncheck it and reinitialize and it automatically gets checked again... any thoughts?
 the level/ramp/x10 scan automatically gets checked too.
 should update on ack be checked?
 Edited by funbobbybaby69 - May 03 2010 at 11:14
        | grif091 Super User
          After unchecking Status Scan, click on Save PLC/PLM Settings, then Exit PH2.   I think just clicking on the Save Settings will save the current settings but Exiting does not hurt anything.  I do not run with Update on ACK.
           | Posted: May 03 2010 at 11:50 | IP Logged |   |
 |  The Level/Ramp/X10 scan has no affect unless doing a Status Scan to begin with.  The Local Level/Ramp/X10 requires additional Insteon commands to retrieve that information beyond what is done for a normal Status Scan.
 Lee G
          Thanks Lee, i tried that (clicking save) but when ph loads it is checked again.
           | Posted: May 03 2010 at 11:58 | IP Logged |   |
        | grif091 Super User
          Are you on 2.1b.  When I click Save PLC/PLM Settings I get a popup window asking to confirm the action that the new settings will become permanent on the next start or restart.  When I Exit and restart PH2 the new settings are in effect.  If that is not the way your 2.1b is acting I have no suggestions.
           | Posted: May 03 2010 at 12:39 | IP Logged |   |
 Lee G
        | BeachBum Super User
          You might go to Setup-Controllers-Settings and uncheck them there and then do a Re-Init.
           | Posted: May 03 2010 at 12:43 | IP Logged |   |
 Pete - X10 Oldie
          Yes im on 2.1b.  Pete got it, it was checked off under the setup-controllers-settings.  I unchecked it, clicked save and restarted ph.  It stayed uncheck.
           | Posted: May 03 2010 at 13:19 | IP Logged |   |
 |  Thank you very much for all your help!!!
 Rob
