| krommetje Super User
          Hey guys,
           | Posted: March 15 2010 at 10:38 | IP Logged |   |
 Here I am again... I've found this little thing:
| Code:
       | ' Moonphase.vbs
 ' 3/16/2002
 ' Copyright Paul R. Sadowski <aa089(at)bfn.org>
 option explicit
 MoonAge(Date)
 Sub MoonAge(strDate)
 dim tmp, arrtmp, strmonth, strday, stryear, strsep
 dim yy, y, m, d, p2, mm, k1, k2, k3, l, j, v, ip, ag, dp, di, la
 dim lo, po, rp, np, phase, thisphase
 Tmp = InStr(1, strDate, "/")
 if Tmp <> 0 then
 strSep = "/"
 else
 Tmp = InStr(1, strDate, "-")
 strSep = "-"
 end if
 arrTmp = Split(strDate, strSep,3)
 strMonth = arrTmp(0)
 strDay = arrTmp(1)
 strYear = arrTmp(2)
 Y = strYear
 M = strMonth
 D = strDay
 P2=2*3.14159
 YY=Y-int((12-M)/10)
 MM=M+9
 if MM>=12 then
 MM=MM-12
 end if
 K1=int(365.25*(YY+4712))
 K2=int(30.6*MM+.5)
 K3=int(int((YY/100)+49)*.75)-38
 ' JD for dates in Julian calendar
 J=K1+K2+D+59
 if J>2299160 then
 ' For Gregorian calendar
 J=J-K3
 end if
 ' J is the Julian date at 12h UT on day in question
 ' Calculate illumination (synodic) phase
 V=(J-2451550.1)/29.530588853
 V=V-int(V)
 if V<0 then
 V=V+1
 end if
 IP=V
 ' Moon's age in days
 AG=IP*29.53
 ' Convert phase to radians
 IP=IP*P2
 ' Calculate distance from anomalistic phase
 V=(J-2451562.2)/27.55454988
 V=V-int(V)
 if V<0 then
 V=V+1
 end if
 DP=V
 DP=DP*P2: ' Convert to radians
 DI=60.4-3.3*COS(DP)-.6*COS(2*IP-DP)-.5*COS(2*IP)
 ' Calculate latitude from nodal (draconic) phase
 V=(J-2451565.2)/27.212220817
 V=V-int(V)
 if V<0 then
 V=V+1
 end if
 NP=V
 NP=NP*P2
 LA=5.1*SIN(NP)
 ' Calculate longitude from sidereal motion
 V=(J-2451555.8)/27.321582241
 ' Normalize values to range 0 to 1
 V=V-int(V)
 if V<0 then
 V=V+1
 end if
 RP=V
 LO=360*RP+6.3*SIN(DP)+1.3*SIN(2*IP-DP)+.7*SIN(2*IP)
 ' phases from
 'http://home.hiwaay.net/~krcool/Astro/moon/moonphase/
 Phase = Array ( "new", "waxing crescent", "in its first quarter", _
 "waxing gibbous", "full", "waning gibbous", _
 "in its last quarter", "waning crescent" )
 select case int(AG)
 case 0, 29
 ThisPhase = 0
 case 1, 2, 3, 4, 5, 6
 ThisPhase = 1
 case 7
 ThisPhase = 2
 case 8, 9, 10, 11, 12, 13
 ThisPhase = 3
 case 14
 ThisPhase = 4
 case 15, 16, 17, 18, 19, 20, 21
 ThisPhase = 5
 case 22
 ThisPhase = 6
 case 23, 24, 25, 26, 27, 28
 ThisPhase = 7
 end select
 wscript.echo "Moon's age (days): " & Int(AG)
 wscript.echo "Moon's phase: " & Phase(ThisPhase)
 wscript.echo "Distance (Earth radii): " & FormatNumber(DI,2)
 wscript.echo "Ecliptic latitude (degrees): " & FormatNumber(LA,2)
 wscript.echo "Ecliptic longitude (degrees): " & FormatNumber(LO,2)
 End Sub
 How can I get this into PH as a macro which stores the output in the VBS as a GV?
 or do any of you guys have a macro already in use?
 Peter
 Edited by krommetje - March 15 2010 at 10:44
