           | Posted: November 29 2015 at 14:16 | IP Logged
Jaaay,
 1. With the virtual smarthome bridge, you would be
 limited to the commands that are preprogrammed into
 the bridge. That would be one of the cons. The
 advantage to this method would be not having to say
 "ask keyword to" or "tell keyword to" type constructs.
 With your own Alexa skill, you would be able to define
 or use virtually any vocabulary.
 2. Yes, you have more control over the commands and
 vocabulary but must use the keyphrase (which probably
 isnt so bad).  Havent looked into IFTTT yet or what
 capabilities are available there yet.
 Jeff,
 Appreciate it. I may take you up on that offer if I
 start to run into some snags. So far I setup the skill
 and have been playing with it but havent revisited it
 to see what else I can do to improve it. Hopefully
 I'll get a little time to play with this some more as
 it seems to have alot of interest.
 Steve,
 Definitely sounds like I need to look into the IFTTT
 aspect of Alexa. The main thing I don't like with the
 way Im currently doing it is to have to create a
 Lambda account and go through the issues of setting it
 up to talk to PowerHome. If I can bypass this and just
 have IFTTT ultimately send the recognized phrase to
 PowerHome then this would greatly simplify things. I
 originally wanted to just have the skill talk directly
 to the PowerHome machine but this requires SSL to be
 enabled on PowerHome and all the issues with getting a
 certificate and the like. Plus, it would appear that
 not everyone is able to use SSL on their PowerHome
 machine as the incoming traffic may be blocked by
 their ISP. Still, something else I may need to look
 into to bypass the Lambda account.
           | Posted: December 08 2015 at 14:39 | IP Logged
Relevent read to this Echo thread.
 http://www.charmedquark.com/vb_forum/showthread.php?t=12271
 Inserting links not working for me :(
  Edited by smarty - December 08 2015 at 14:42
           | Posted: January 20 2016 at 13:16 | IP Logged
I have been re-reading this post and looking more at how to get *any* PH functionality from the Echo.
 Until/if Dave releases something better... and not being a programmer myself; the IFTTT Maker Channel seems most promising to me.
 The Maker channel can send a web request to PH's webserver (assuming it faces the outside world).  Mine does face the outside world via a noip.me DNS account.
 My question for anyone would be:
 Since the PH web browser must be accessible from the outside world, how would the login authentication be handled so that only authenticated web requests would cause the PH browser to execute commands?
 If I get past this obstacle, it appears to me that putting formula or macro statements into the web request seems doable (once authenticated).
 While this may not be the optimum way forward, for us none programmer types, it seems it may be all there is.
           | Posted: January 22 2016 at 16:13 | IP Logged
Steve,
 Ive briefly looked at the IFTTT (IF This Then That)
 site and it appeared like it might be a good solution
 but I didnt spend enough time to see how involved it
 would be.
 In any event, just about any Echo integration will
 involve using the webserver (what Im currently working
 on with an Alexa skill will also require this). The
 virtual bridge option thats currently available
 wouldnt require external webserver access but still
 uses it internally which would still require
 authentication passing unless you've whitelisted the
 internal IP.
 Depending upon the authentication method you've chosen
 for your PH webserver will determine how you pass that
 information. If you've chosen "Basic", this is just a
 base64 representation of your userid:password and is
 passed as part of the http header. Keep in mind that
 this is not secure unless you're also using SSL as
 anyone that is able to monitor your HTTP traffic can
 capture this info and base64 decode it for your userid
 and password. Most HTTP program calls or functions
 will provide some mechanism to pass the basic
 authentication as part of the call. Most URL functions
 that Ive seen (including the ones Ive built into
 PowerHome) allow you to pass the credentials as part
 of the URL such as this:
 http://userid:password@your_PH_IP_or_dynamic_dns/ph-
 cgi/more_parameters
 If you're using the "Basic" authentication method, you
 should be able to do this but its not secure unless
 you're using SSL.
 If you're using the "Cookie" authentication (more
 secure), then the authentication info is passed as a
 cookie. The actual userid/password info is never
 accessible via this method (the cookie contains a one
 way hash of a salt generated by PowerHome) but the
 cookie could be intercepted and stolen. SSL of course
 makes this method secure as well. If you're using this
 method, then you mush somehow have the remote system
 include the authentication information as a cookie
 when the HTTP call is made. The easiest way to get a
 valid cookie would be to "borrow" one from an existing
 authorized user by reviewing the eventlog for a past
 webserver request. You'll see something in the log
 that says:
 Cookie: phauth=ABCDEFABCDEF....a bunch of random hex
 digits.
 If you take this entire string starting with "phauth="
 and all the following hex digits and pass it as a
 cookie with your request, then the command should be
 authenticated.
 Once you're able to make your requests and pass
 authentication, then you need to decide how you're
 going to control PowerHome. One of the most basic is
 to just use the internal CGI function EVAL. This will
 allow you to pass any PowerHome formula as part of the
 URL and have it evaluated which can call a macro, turn
 on a device, etc.  It looks like this:
 http://yourPHmachineIP/ph-cgi/eval?
 formula=ph_insteon("TEST",ion,255)
 or
 formula=ph_macro("TEST")
 Keep in mind, you'll probably want to "escape" the
 formula section (you can read about escaping URL's
 through Google). Another option is to call a PSP page
 and have that page perform additional processing, etc.
 but that would be beyond the scope of this post.
         mike0999 Groupie
 Online Status: Offline Posts: 56
           | Posted: March 04 2016 at 00:52 | IP Logged
New Amazon Echo Dot - Even more possibilities.
           | Posted: March 04 2016 at 03:41 | IP Logged
 I sure appreciate your note two entries above, but for the life of me, I can't seem to make the IFTTT Maker channel produce the needed PH "authentication strings" (cookie or name/password...cookie approach would be preferred).
 With the advent of even more Echo devices (esp. the dot), I see so many new ways I want the Echo to interact with my PH system.
 If ANYONE can put a tutorial (for none computer scientists) on how to authenticate PH so that web cgi commands can be passed from the Echo to PH's webserver via the IFTT Maker channel, I (and likely many others) would be HUGELY grateful.
  Edited by smarty - March 04 2016 at 03:42
           | Posted: March 04 2016 at 14:10 | IP Logged
Steve,
 I created an account on IFTTT and played around a little. Initial research does not look like there is a way to pass a cookie but I'll keep playing with it. I was able to use
 the Maker channel as an Action to successfully call into PowerHome with basic authentication.
 As a test, I just created a simple recipe with Maker as the trigger and Maker as the action. For the trigger action I create an event with ID of DWH001 and used the following
 URL to trigger my recipe (I changed the key below so as to protect my trigger):
  https://maker.ifttt.com/trigger/DWH001/with/key/cKJDKEJkdkej 8k4d82kkrKDEkw
 For the Maker action, I used the following:
 URL:  http://testuser:testpass@123.456.789.123:5555/ph-cgi/eval?ph _macro("TEST1")
 Of course, the userid, password, IP, and port were changed to match my actual server.
 Method: GET
 Content Type: Text/Plain
 Body:
 Body was left blank. When I triggered the "trigger" URL, I got the following in the PowerHome log:
 GET /ph-cgi/eval?ph_macro(%22TEST1%22) HTTP/1.1
 Content-type: text/plain
 host: 123.456.789.123:5555
 authorization: Basic dGVzdHVzZXI6dGVzdHBhc3M=
 x-newrelic-id: XBMGV34QGwQZXllRDsQ=
 x-newrelic-transaction:  QxXYZ7EAC5AFVFsABYUEFkYdUFIOFQZOElNZVz2LYEqEUQsDBFhWUmkUG0MH UytLBAcGTxVs
 Connection: close
 The main thing I needed to verify is the line: authorization: Basic dGVzdHVzZXI6dGVzdHBhc3M=. This is webserver userid and password that PowerHome requires for the basic
 authentication and it is proper so the Maker channel does properly support passing basic authentication credentials on the command line.
 I'll keep playing and see if there is a way to get cookie authentication working but basic authentication is working pretty well.
           | Posted: March 04 2016 at 23:20 | IP Logged
           | Posted: March 09 2016 at 04:42 | IP Logged
Found an error below....
  URL:   http://testuser:testpass@123.456.789.1 23:5555/ph-cgi/eval?ph_macro("TEST1")
 Should be:
  URL:   http://testuser:testpass@123.456.789.1 23:5555/ph-cgi/eval?formula=ph_macro("TEST1")
dhoward wrote:
       Steve,
 Method: GET
 Body:
 Connection: close
  Edited by smarty - March 09 2016 at 04:42
         jonkjon Groupie
 Online Status: Offline Posts: 77
           | Posted: April 08 2016 at 13:03 | IP Logged
Jay
 I notice that your on/off url's are going to port 8080.
 Is 8080, in your case, the PH server or is that the HAB
 port?
 i.e. Are the on/off url's supposed to be sent to the HAB
 or PH?
 Thanks for your guide and info on this.
 --Jon
         Jaaay Newbie
           | Posted: April 09 2016 at 15:03 | IP Logged
Jonkon.. That is my PH port 8080.. From what I
 remember I was running both on the same server so I
 needed to start the HA bridge on a different port.
 I used the following to start the HA bridge server
 with a different port: (all one line command)
 java -jar amazon-echo-bridge-0.1.3.jar --
 upnp.config.address=192.168.1.50 --server.port=8081
 I also remembered starting to have issues at 20
 devices.. Not sure if the HA bridge has been fixed for
 that issue. I also remember having to clear the
 devices before reloading them if there was a change.
         jonkjon Groupie
           | Posted: April 09 2016 at 16:08 | IP Logged
Thanks Jaaay;
 I got it setup using the builtin configurator. I am using the 0.2.1 jar. The configurator makes this a breeze to set up. I currently have 14 devices in there. I haven't received my Echo yet so we'll have to see.
 I would also like to get my Limitless LED bulbs working through PH. I have a small Windows application that controls them but if I recall there was an issue with UDP commands through PH. I know there are some bindings available through the HA bridge but I'd rather find a command from PH to do it. I'll have to go back and see where I was running into problems.
 Again, thanks for all of your help....
 --Jon
           | Posted: April 10 2016 at 12:09 | IP Logged
jonkjon wrote:
       Thanks Jaaay;
 ...I would also like to get my Limitless LED bulbs working through PH. I have a small Windows application that controls them but if I recall there was an issue with UDP commands through PH. I know there are some bindings available through the HA bridge but I'd rather find a command from PH to do it....
 --Jon |
 I too am waiting for native PH support for the UDP commands....what is the windows program your presently using?
         jonkjon Groupie
           | Posted: April 10 2016 at 18:49 | IP Logged
It's a simple Windows form application I wrote to work with the Limitless LED API. It really was just to figure out the commands etc.
 I wound up just using Domoticz on a linux machine for now passing json commands to the HA Bridge. I don't have my Echo yet to test it all out but it is configured and ready to go when it gets here this week.
 --Jon
         DennisWeller Newbie
           | Posted: April 12 2016 at 14:41 | IP Logged
I know this is about the Amazon Echo, but has anyone on here had any
 experience at all with Samsung's 'Smart things'?
         jonkjon Groupie
           | Posted: April 13 2016 at 18:24 | IP Logged
Just a follow up on the Echo and HA Bridge with PH. I got everything setup and interaction with PH is perfect. The new configurator in the bridge is also really nice.
 I did run into the device limit where the echo stopped recognizing there were devices. The limit for me was 28 devices, add one more and it will tell you it can't find any devices. The workaround for that is to run multiple instances of the bridge on different ports.
 I also had to get a little creative with some of the names for devices as the one's I originally setup conflicted with built in commands. I would suggest avoiding names that contain the word "Music".
 Again, thanks for the original info in setting this all up!
           | Posted: May 10 2016 at 07:48 | IP Logged
An update on this general topic....
 While the IFTTT Maker channel is an option for PH voice control, your webserver password is "kinda" exposed (as mentioned above).
 So, I started looking into the GitHub Armzilla HA-bridge Hue emulator (also mentioned above).  However, that project has went dormant, and a new "fork" has become the "dominate" Hue emulator bridge.  This new and very refined project can be found  here
 It appears to me that this approach is safer (no passwords exposed to the outside).  It allows for On/Off/Dimming of devices, as well as any custom PH macro /formula calls through PH's webserver (done locally).
 I now say turn on/off kitchen lights, and the echo says "OK".  No more trigger words...
 Very happy with the possibilities of MUCH PH integration....but I am just starting to scratch the surface of HA voice control and interaction.
  Edited by smarty - May 10 2016 at 07:55
         jonkjon Groupie
           | Posted: May 11 2016 at 10:43 | IP Logged
smarty, looking over the link you posted for the newer fork I was wondering if that has the configurator.
 --Jon
           | Posted: May 11 2016 at 14:40 | IP Logged
 --Jon |
 Yes it does.  It is even more advanced.  The configurator page would be found at:
 //ip_address_of_emulator_host:8080
 Note that this is not the same location as the Armzilla configurator.
 Also, initially I had an issues opening this page when using IE-11.  Use Chrome or Safari and it will load and display properly.
         jonkjon Groupie
           | Posted: May 11 2016 at 17:48 | IP Logged
Thanks for the information on this. I'll probably keep my setup for now as it is working and fairly easy to maintain.
 It looks like Amazon keeps adding to their builtin keyword list as my "Netflix" command no longer works. I just get a "thump" sound.....
 On a side note, are you using the Milights or Hue? I had to go through another HA package to get the commands to work for the Milights. Does this offer a way to just add one bulb as a device and you can issue voice commands like "Alexa, set overhead lights to blue"? I had to create devices and use python scripts to get that functionality. I don't have to use any keywords or anything just; "Alexa, turn on blue lights."
 Thanks again...
 --Jon
  Edited by jonkjon - May 11 2016 at 17:58
