         RichardL Senior Member
           | Posted: March 25 2017 at 15:01 | IP Logged
I have just set up the 2843-222 open/close sensors to alert me when my garage doors go up, down, or remain open.
 Most of the time all is OK, but my problem is that at random, I am not getting a reply that can trip a trigger.
 There are many dual-band devices in my home and 2 pair of access points.  Due to these problems I moved one pair of access points into the garages, they are set up OK on 2 phases.  I performed tests and am still getting missed events.
 Under devices, the Clear Failed is constantly red.
 Failed matches and Ext Failed Matches are red and 5
 Also when I set them up, there are no direct device types, I have the device types as a 2458D3 – AccessPoint LampLinc
 IEngine is I2CS, “Use Ext for ALDB” is checked.
 Running PH 2.1.5d
 Upon an open/close - something is getting through as I see “Grp Brdcast success/fail” events, but not always the Group 1 On or Off that I need.
 Any thoughts or advice?
 Thank you!
 Event Log:
 Garage door 2 opening, all OK, trigger ran:
 Garage door 2 closing, all OK, trigger ran - but also got 2 Grp Brdcast success/fail events:
 Garage door 4 opening, OK, trigger ran:
 Garage door 4 closing, NG, no trigger ran, but got 2 Grp Brdcast success/fail events:
 Triggers (all have a Boolean of 1):
 Also when I clear the Comm Failed, I see timeouts:
           | Posted: May 10 2017 at 11:52 | IP Logged
Still fighting this issue with the battery/RF 2843-222 open/close sensors:
 To generalize – I am always getting “Grp Brdcast success/fail” events, but NOT always the Group 1 On or Off events that I need to kick off a trigger.
 Would you think that the issue is RF reception or powerline noise?
 I have the same behavior on all 4 sensors.
 If it is either reception or noise, then why do I always/dependably get the “Grp Brdcast success/fail” events?  I would imagine that either reception or noise would randomly thwart “Grp Brdcast success/fail” events, just like the Group 1 on/off events…
 I am considering replacing the open/close sensors with an IOLinc solution.  No RF, just powerline.
 Thoughts?
 Thank you!
         nick7920 Senior Member
           | Posted: May 14 2017 at 20:44 | IP Logged
I had similar problem while back and switch to IOLinc
 and it works great. My X10 even worked fine but  insteon
 RF had an issue.
