| Posted: May 04 2002 at 09:30 | IP Logged
I just discovered that Descriptions, like ID's, cannot contain certain characters! I don't recall seeing this in the manual.
The problem this caused was that I had buttons that would not display in the Control Center.
Tony
| Posted: May 04 2002 at 22:09 | IP Logged
Hmmm...thinking about this one, I dont believe I put restrictions on the Description field...but my guess is that the only character that could cause the behavior you describe would be the single quote...Am I right? I'll either put a restriction so it cant be used or come up with a way that will not cause a problem.
| Posted: May 05 2002 at 19:30 | IP Logged
You got it! I was using "steve's" and that blew it up.
Tony
