Posted: May 03 2002 at 21:37 | IP Logged
Well, maybe one or two more...
- Allow comments (i.e. remark, etc.)
- Device/Code Replacement
- Instead of C10, you could use "Table Lamp"
- Global search and replace
- For when you rearrange addresses!
Tony
Posted: May 04 2002 at 22:15 | IP Logged
The first one is taken care of in the next release. Macros now have a Comment command. Send Keys already does in the current version.
Concerning the 2nd request...do you mean like in macros and send keys?
Give me a little more info on the 3rd request...I think I know what you mean though. Probably within Macros, (maybe others as well), search for a string and replace with a different string. When this search takes place, should it search all tables and all fields???
Posted: May 05 2002 at 19:50 | IP Logged
1st: Cool!
2nd: Yessir! Triggers, too! I, too often, need to have two Explorer windows open to answer the question, "What was the <fill in the blank> address?". Just having a name replace the controller number, house code, and device code would really speed things up (as far as my programming goes). I still have not used Send Keys for anything but sending keys, though. ;-)
3rd: Standard global S&R, yep. I assume that every section is a table (triggers, macros, etc.)?
Tony
Posted: May 13 2002 at 21:50 | IP Logged
Another one...
Right-clicking on a macro name in the PH Explorer left pane should give the same options as right-clicking on a macro name in the right pane of the PH Explorer instead of shrinking the left pane to nothing and blowing up the width of the right pane.
If half of us like it the way it is, then, never mind! ;-)
Tony
Posted: May 15 2002 at 14:24 | IP Logged
I'll look at this and see what I can do.
