| Posted: December 17 2014 at 20:41 | IP Logged
All,
PowerHome version 2.1.5b is now available for download here: http://www.power-home.com/download/ph215bsetup.exe
If you are upgrading from 2.1.5 or 2.1.5a, then no need to uninstall, just rename your PowerHome directory and then install fresh. Copy over your database and pwrhome.ini files (as well as any others) and you should be good to go.
If you are upgrading from a version prior to 2.1.5, see the more detailed upgrade instructions in the 2.1.5 post.
MD5 for the 2.1.5b download is: c69e59e1f83a2649714ad76f0dbaeabd
See this forum thread for the discussion of 2.1.5b along with the change notes:
http://power-home.com/forum/forum_posts.asp?TID=4458&PN=1
Edited by dhoward - December 19 2014 at 09:30
