        | gg102 Senior Member
           | Posted: July 23 2014 at 18:50 | IP Logged |   |
 I know you're currently busy with other items, but I also know you're planning on an update to the CC.  So, I had another idea that might be useful.
 When you right click on the CC to get into the design mode and you put up the little window with the options to set, (ID, Action, Font, Color, Border, Boundary) how about under that window and visible at all times, add two lines that show the x and y locations, and under that the height and width of the selected object.
 This would be an easy feature to add, and would make it easier to locate an object across multiple CC pages.
 Just a thought.
          gg,
           | Posted: August 04 2014 at 18:18 | IP Logged |   |
 Should be simple enough to do. Ive added it to the to-do list.
        | gg102 Senior Member
           | Posted: August 05 2014 at 20:10 | IP Logged |   |
 I'd like to make another request.
 In Macro's when you edit a macro formula, can you make that pop up window (the Formula Builder window) resizable?  There are so many times I find that window too small and inconvenient.
 Thank you Dave.
          gg,
           | Posted: August 08 2014 at 13:58 | IP Logged |   |
 Added to the to-do list.
