Posted: May 15 2007 at 22:57 | IP Logged
Hmm... A search turns up nothing here.
GSOUZA Groupie
Posted: May 16 2007 at 12:25 | IP Logged
here is the information at the FAQs:
-- Does PowerHome have an interface for NetRemote?
No. However, a simple VB app could be written and interfaced to PowerHome using the Windows Messaging Interface. The internal COM routines could also be used to communicate with the NetRemote Interface. Once I acquire this interface, I will add support for it.
-- Does PowerHome have an interface for MainLobby?
No. We will be creating an interface for Girder shortly. This should allow for interfacing to MainLobby.
GS
Posted: May 16 2007 at 13:43 | IP Logged
Hmm!
Posted: May 19 2007 at 22:10 | IP Logged
GS,
No work has been done on NetRemote support yet (actually it would be great if some other enterprising soul decided to do this as a plugin...hint, hint).
You can send socket commands to the socket server interface using any program of your choice. It just has to be in the proper syntax (this is detailed in the Users Manual and should be one of the few items that are not out of date). Also, the PH Socket Command download should include the VB source code. You should be able to easily wrap this code into other projects so you don't have to use the command line.
GSOUZA Groupie
Posted: May 19 2007 at 22:19 | IP Logged
Dave, my main interest is on Girder. not netremote. i think netremote is one step after what im doing now.
i use girder to do whatever i need. send commands from one computer to other and now its working with PH using PH sockets and PHSS command line.
i will try to use the sockets client that girder already have to talk with PH socket server directly.
cya
Gustavo
