| Posted: December 17 2008 at 17:17 | IP Logged
Unless the forum did tricks you might try this
if(hour(now())> 23 or hour(now())<=5,1,999)
Lazyman Groupie
| Posted: December 19 2008 at 00:34 | IP Logged
Thanks!! It works.
Now, how can I change it so that instead of checking to see if "Master Bedroom" is on, it will check to see if "Master Bedroom" is at 35 or brighter? What is the command to check the level of a light.
(and thanks again)
| Posted: December 19 2008 at 08:46 | IP Logged
Check out ph_getinsteonlevel or ph_getinsteonlevelrt depending on whether you get it from PH or the device.
