Subject Topic: PH freezing 2412U Post ReplyPost New Topic
grif091
Posted: December 09 2009 at 19:29 | IP Logged Quote grif091
If you are asking can it be used as a conroller to interface with the powerline like a PLC or PLM, no.
Lee G
drewtibs
Posted: December 15 2009 at 18:09 | IP Logged Quote drewtibs
In my discussion with homeseer, where I was having PLM hanging issues as well, they pointed out that I had checked in device manager under "USB controllers" to allow computer to manage power to these devices. I uchecked and that made it so I could go a couple of days before the 2412U hangs and freezes PH, with corresponding "cannot communicate on com3" when restarting PH.   I will try powered USB hub.
I am on my second 2412U, my third computer, (dell opti 270) and second HA software. (I tried homeseer with same results". So its definetly not the HA software, but the SH hardware. Does moving to a serial interface fix these issues? I've about had it with this freezing issue. There is no hope of selling this to other people with this poor state of reliability. Thanks to everyone who has commented on this issue and the PH community in general.   Drew.
Back to Top View drewtibs's Profile Search for other posts by drewtibs
grif091
Posted: December 15 2009 at 18:51 | IP Logged Quote grif091
I've been running with a Serial PLM since PH2 Beta (not the Alpha) came out and have never had a PLM hangup that I can remember. Others seem to run okay with a USB PLM. May well be the type of USB connection on a given PC.
Hopefully others will jump in with their USB and Serial PLM experiences.
Lee G
BeachBum
Posted: December 17 2009 at 14:50 | IP Logged Quote BeachBum
As I have said before I run a serial PLM with a USB to serial adapter. Mine is rock solid like Lee’s, BUT I have seen PH lockup when there has been a loss of communications between PH and the PLM. PH seems to go into endless error recovery although I don’t think it is the same problem. The problem Drew is having sounds external to the native computer systems. Either the same software is loaded on all the systems and is causing a glitch as in a driver is replacing Smarthome drivers, or there is something on the powerline which is unlikely.
Pete - X10 Oldie
smarty
Posted: December 17 2009 at 15:07 | IP Logged Quote smarty
I have a serial PLM (no usb adapter). I use an 8 port serial card. My PLM has been solid. All I can say is that in general, I like serial devices over usb type devices...to me, there seems less to go wrong.
My usb CID modem sometimes gets flaky, but I think it might be because of a loose fitting usb connection...
NorthernAl
Posted: January 01 2010 at 17:57 | IP Logged Quote NorthernAl
My battle seems to be over. I returned my second 2412U for a 2412S (serial) and have been running now for a week without a crash.
I went through two usb (2412U's) and tried a powered USB hub with no luck. Thankfully that frustration is now over - I even had a spare serial port so did not need to buy anything else. Keeping fingers crossed but seems like I have a working and stable Insteon system again.
The 2412U seems to work for some but if you have a choice (you have an open serial port), I'd stay away from it and stick with the serial version. I think it (usb version) has a serious design flaw (not sure if SM will admit and fix it or not).
Thanks everyone for the input and help on this. It was your comments on the serial version that led me to try it and finally resolve a year of Insteon frustration (which started with a failing 2414U, two 2412S, usb hub, lots shipping costs, etc.).
Happy 2010!
Back to Top View NorthernAl's Profile Search for other posts by NorthernAl
BeachBum
Posted: January 01 2010 at 18:52 | IP Logged Quote BeachBum
Yep welcome to the club.    I'm glad the saga is over. Now onto bigger and better adventures.
Pete - X10 Oldie
Anthony
Posted: January 01 2010 at 21:12 | IP Logged Quote Anthony
Interesting information on this forum. I recently purchased PH2, 2414U and about 12 Insteon devices. I eventually plan to expand my entire house and office with these devices. IF I CAN GET IT TO WORK. I have spent hours before I came across this forum. It makes sense about the USB hub and I will try that. I also have another question. I currently have my 2414U plugged into an AC outlet next to my computer. The other recepticle has an APC 1400 UPS plugged into it. I could not get PH2 to discover any of the three devices currently attached to that phase. When I moved the 2414U to another outlet (on the same phase) outside the room, it did discover, but I have freezing problems and all kind of unknown devices linked. Any ideas?
Thanks Anthony
Back to Top View Anthony's Profile Search for other posts by Anthony
grif091
Posted: January 01 2010 at 21:25 | IP Logged Quote grif091
A UPS is often a source of Insteon signal attenuation. The power supply does a good job of cleaning up the powerline so noise does not make it through the UPS. Unfortunately the Insteon signal looks like noise. The PC power supply can have the same affect. Generally a Smarthome FilterLinc between the UPS and the outlet solves the problem. It is a good idea to put all the peripherals on the FilterLinc so you may need a 10A version. You can temporarily put the 2414U on an extension cord and plug it into a circuit in another room which is generally a different circuit and far enough away to eliminate the problem. The sales page for the 2414 recommends the use of a FilterLinc.
Not sure this will resolve the freezing problem. That may be a USB related problem rather than a powerline noise problem.
Edited by grif091 - January 01 2010 at 21:26
Lee G
grif091
Posted: January 02 2010 at 14:00 | IP Logged Quote grif091
The other thing that may explain the strange links is that at times devices are received with active links already in the device. You will find several posts about this on the Smarthome forum. It is a good idea to factory reset any new device before beginning to use.
Lee G
Mitch
Posted: January 16 2011 at 21:59 | IP Logged Quote Mitch
I found this thread and a similar one from 2007 expressing the same problem. In the previous one Dave mentions that he would try a fix in the next version, but I guess that did not work. I've had problems with freezing off and on - requires a cpu reboot to fix - maybe once a month in the past, but have seen several of these in the last few weeks. In my case I lose both the USB serial port and the Com 1 serial port. I am using Eltima Serial port splitter software, so my com1 is a virtual port.
At first I thought the freezing were occurring because of the macros I had that sent data to the com1 port in response to a keypad/paddle press, but I tried a "rats on speed" test (rapidly toggling the keypad button), and PH performed beautifully will all serial commands getting to the controller just fine.
So I'm giving up on my USB PLM and swapping it for the serial version (dual band). Just thought I would check to make sure this is still the prevailing wisdom on this problem - has it solved the PH freezes for those of you who had this issue? Wish I had read this thread before I got the USB version.
Mitch
Back to Top View Mitch's Profile Search for other posts by Mitch
<< Prev Page of 2
