Subject Topic: Beta V2R0 Problems Post ReplyPost New Topic
BeachBum
Posted: September 16 2008 at 09:27 | IP Logged Quote BeachBum
Up and somewhat running on V2. The Timed Events IDs are showing _OS_xx where xx = a number. No timed events, which are next to pop, are showing in the Device Status screen. As predicted, ControLinc and RemoteLinc did not respond to the query. All other devices responded.
WEB site looks great but if you copy and paste the text remember to change the font color to black.
Pete - X10 Oldie
nadler
Posted: September 16 2008 at 09:43 | IP Logged Quote nadler
Dave added an ID Field to the Timed Events so that you
can now give them a name, like you do to macros. So
_OS_xx is the default name that was automatically given
when you updated to PH2. You can go into Timed Events
and change the name to something more meaningful.
Also note that Dave added a Disabled checkbox to Timed
Events. So now you can disable a Timed Event without
deleting it. This was a much requested feature.
As to the Device Status screen. I had exactly the same
question. PH2 now shows a list of pending Timed Events
in that screen - starting on the 2nd line - so just
resize the window and you will see ALL the upcoming
TImed Events.
Noel
BeachBum
Posted: September 16 2008 at 09:51 | IP Logged Quote BeachBum
Oooh that’s a little gotcha. But does make sense. Everything else seems to be working at this point.
Thanks for the input Noel…
Pete - X10 Oldie
BeachBum
Posted: September 16 2008 at 10:20 | IP Logged Quote BeachBum
Does anyone know what values that need to be change to compensate for the new PowerHome Status windows sizes.
Pete - X10 Oldie
Posted: September 16 2008 at 19:13 | IP Logged Quote dhoward
Pete,
With the PH Status screen (I'll change this to be consistent to the other screens if everyone would like), just open it up and then you can drag and resize all of the individual windows to your liking. When you're happy, right-click on the window (not on the title of a sub-window) and select "Save" from the pop-up menu. PowerHome will save and use these settings everytime you open the window.
BeachBum
Posted: September 16 2008 at 20:35 | IP Logged Quote BeachBum
Thanks Dave.. Did not know about the save. Good job on this version.
Pete - X10 Oldie
BeachBum
Posted: September 17 2008 at 08:16 | IP Logged Quote BeachBum
The PLM locked up last night but I didn’t have the Log running. What I did notice was PH continued as if nothing was wrong other than it was not issuing commands to the PLM. When I restarted PH I receive the following msg. “Get IM info command failed for Insteon PLM PLM. Attempting to restart controller.” Macros started but no PLM activity. Pulling the power to the PLM and restarting PH fixed the problem.
Don’t know if this belongs here but V2R0 did not fix this communication glitch.
Edited by BeachBum - September 17 2008 at 08:17
Pete - X10 Oldie
